-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   tranny rebuild questions (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/3846-tranny-rebuild-questions.html)
smpiers 08-30-2001 12:49 PM
What is the average cost of rebuilding a transmission?
Cost of someone supplying a rebuilt transmission?
Are trannys more intense to rebuild than engines?
sammyg2 08-30-2001 06:22 PM
I rebuilt mine, not all that expensive. I replaced three syncros, one bearing, and all seals (from pelican).
Only problem is, setting the gear backlash and bearing pre-load requires some unusual tools.
Unless you are very experienced with manual transmissions and/or differentials, leave it to an expert.
A decent transaxle can usually be found for around $250 in the junk yards, but will probably need a first and maybe a second gear syncro. No guaranties.
Gerald Gore II (Sam)
73 914 350 small block
