Where can i find the fasteners for the mesh grill on my engine cover? All the pins are there, but no nute or whatever was used is gone. Thanks
------------------ Duane '73 914, '76 912E, & '76 VW BUS (ALL 2.0L) |
914 Geek
Check your local hardware store for "speed nuts". They're flat pieces of metal with an "H"-shaped cut in the middle. The cross-bar of the "H" is actually something of a hole.
You may be able to just push them on, or you may need to twist them on. --DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Dave...Im shocked..yes shocked...
Speednuts/Clips for mounting of lettering, each [Photo] K-591-423-03 $0.70 http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_exteri_main.htm I think these are the same size and have the required rubber to isolate the metal to metal rustathon. -Rich Hilgersom |
Thanks guys, now I can stop that anoying rattle!
