cary's Avatar
Post Tach Pegged ???
Question #2 :
Energize the ignition. Tach pegs to the top.
AND STAYS THERE.
What should I look for ?
TIA
Cary Kutter
77 Euro Carrera w/3.2
PCA Region - Big Sky
Old 08-31-2001, 02:49 PM
Eat-um-up's Avatar
Send a message via ICQ to Eat-um-up Send a message via AIM to Eat-um-up
Post
you got the ground wire at ground and the hot wire at hot? how about the coil. is it plugged into the right side?? if all of that is true sounds like youve got a crossed wire somewhere
Old 09-01-2001, 01:09 AM
cary's Avatar
Post
Thanks for the help.
My Haynes just showed up. Show I'll start tracking them down. I'll match up the wires and the numbers and see where I'm at. then I'll get back to you.
Cary Kutter
Old 09-01-2001, 09:25 AM
cary's Avatar
Post
Coil wire is correct.
The tach wires ?
Pulled out the tach.
The ground wires are on the left spade.
The Black/purple is on the middle spade.
And the red/white is on the right socket.
Is this correct ?
TIA
Cary Kutter
74 914 2.0 ( base model )
Old 09-01-2001, 08:10 PM
Eat-um-up's Avatar
Post
The tach wires ?
Is this correct ?
TIA
thats right on the tach, and im sure that the ground goes to ground on the other end and the red/white goes to a hot. make sure that purple one isnt crosed with a hot, or is grounded out. if thats not the case, i would suspect a bad tach.
Old 09-02-2001, 02:26 AM
cary's Avatar
Post
Going to get out my meters.
Check the RPM @ the coil. Then at the black/purple at the tach end. If I lost the signal I'll go into the relay board connections. Haynes schematic say's the wire goes in one side and out the other.
I'll check the ground for continuity. I think it was loose when I pulled it out. I tightened it. I believe if the ground is loose you'll have no lights on the tach and gas/temp gauge. I remember one night on the way home on the trailer I turned on the lights, and only had lights on the speedometer.
I'll let you know what I find.
Cary Kutter
Old 09-02-2001, 08:01 AM
cary's Avatar
Post
All connections are good and correct. Continuity and Voltage.
Have a good signal on the Black/Purple at the tach. So evidentally, tach is not working.
Cary Kutter
Old 09-02-2001, 09:50 AM
Eat-um-up's Avatar
Post
well i am about aout of ideas. have the tach checked, or get one of the cheap ones from pep boys, or borrow one. plug in the temp tach and check to make sure your circut board in the engine bay isnt at fault. as ive come to understand just about everything in that car goes though that board and its about 90% of all electrical problems. If its your tach i have an extra one from a 74 914 (dont matter what year though) let me know and ill check to make sure its good and ill sell it to you cheap
Sweet Blue 72' 914
Check it out at
http://www.geocities.com/eat_um_up/914.html
Old 09-02-2001, 06:00 PM
