green71's Avatar
Post Long block?
Seems like there's no end to what I don't know about these cars. I thought there were only three 4 cyl. motors: 1.7, 1.8 & 2.0. But recently I've seen the term "1.7l long block" pop up a couple of times. What exactly is this? A modification to a stock motor, or a factory variation on a more standard 1.7l, or what?
Thanks,
Mark
1971 1.7l 914
Old 09-07-2001, 11:50 PM
Stay away from my Member
campbellcj's Avatar
Post
A "long block" is basically a bare stripped engine, with no induction or exhaust systems. But it is complete with the heads and other major stuff. Essentially a "plug and play" engine to swap into a car that already has the fuel injection/carbs and so forth.
FWIW a "short block" is a bare case with the crank, rods and pistons etc installed but no heads or induction/exhaust. It looks like an engine case with a bunch of studs and parts hanging off...
HTH,
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
Old 09-08-2001, 12:07 AM
DDS DDS is offline
Post
Does a long block include clutch and flywheel?
Dave
Old 09-08-2001, 05:13 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Post
Flywheel yes,with end play set but not with the clutch.Steve
Old 09-08-2001, 05:26 AM
