MSD 6A install on a stock 914 1.7l....what am I missing?
I have an extra MSD 6A & a new Blaster 2 coil I want to install on my 914 which is in need of a points adjustment (dwell), and I'd prefer to go optical & install this MSD Setup:
Who carries just the optical pickup & instructions to install an MSD with it? Thanks!! Mark |
SmileWavy Andy http://forums.pelicanparts.com/uploa...1204777747.jpg |
Doesn't the MSD-6 still need some kind of trigger (points, Pertronix, optical, other) to run it?
--DD |
:confused: Andy |
That's what I'm trying to find out: I want JUST the optical points-replacement necessary to trigger the 6A. Since my car is fuel injected, the MSD distributor is not an option from what I understand: besides, my disty is not even 6 months old off it's rebuild.
Mark |
If you want an optical points-replacement to fit in the stock D-jet distributor, you'll want the Crane points-replacement gizmo. That's the only one I know of that goes into the stock dizzy.
--DD |
Isn't this the same thing Dave? I think I can just trigger the MSD off this unit & be done with it. I purchased an MSD coil to go with the MSD 6A on friday. :) BTW: Just installed the Pelican "Special Edition" front spoiler yesterday: excellent fit. I'll upload pictures for your Kudos later. :) |
That's a Hall-effect points replacement, similar to the Pertronix. It will work, but it is not the optical one. Crane is, I think, the only optical one that just bolts right into our distributors.
--DD |
| All times are GMT -8. The time now is 05:15 PM. |
