-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   951 Fuchs on 914/6 GT any issues? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/400833-951-fuchs-914-6-gt-any-issues.html)
rfuerst911sc 03-28-2008 05:25 PM
I want to mount 16x7 and 16x8 951 Fuchs with 23.3mm offset on my 75 chassis with GT metal flares, any issues with these fitting? Any suggestions on tire sizes? Yes I have converted to 5 lug on all four corners.SmileWavy
racer 03-28-2008 05:48 PM
No problems at all.. but they may not appear to fill out the fender flares without some spacers.
The 951s have a 23mm offset as mentioned. However, the lug bolt holes have a "sunken" look compared to 911 Fuchs. As such, 951 7s and 8s at first glance look like 911 6s and 7s (ie the 951 have a smaller appearing "lip").
911 8s would have a larger lip and well, 911 9s also fit in the back and make a great look.
Not sure if 911 8x16s fit up front.. I know 911 8x15s can fit up front though.
For 7/8s you can run (front/rear) either 205/225 or 225/245.
Eitherway, 951 8s, 911 8s and 911/930 9s are all harder to find and more expensive everyday so unless you find a 911 guy who wants the 8s to fit on the front of his car, hold on to them.
TRE Cup 03-28-2008 07:30 PM
This is my 6 with 951 8 x 16 up front 225/50 RA 1 and 911 8 x 16 rear with 245/45 RA1.
Point is the front fenders are completely stock, so this gives you an idea on how far inset this combo would look with GT flares
(Rear is metal added in 2 sections to give the needed clearance and look)
http://forums.pelicanparts.com/uploa...1206757794.jpg
jhora 03-28-2008 08:19 PM
F 7x16 and R 8x16 on my 70' 914-6
Kumho Victos F 225/50/16 R 245/45/16
Fit fine
http://forums.pelicanparts.com/uploa...1206760606.jpg
rfuerst911sc 03-29-2008 04:08 AM
Fit fine
John are your Fuchs 951 or 911 offset? Looks great. Are you running any spacers? Thanks
jhora 03-29-2008 08:16 AM
Thanks..
Both are 911 offset with no spacers...here are the numbers
Fronts 7x16 911.361.020.44 ET 23.3
Rears 8x16 911.362.117 ET 10.6
SlackeR32 04-09-2008 01:04 PM
http://forums.pelicanparts.com/uploa...1206757794.jpg[/QUOTE]
TRE, Could you please share some more info on your setup? Specifically, how you've modified the fenders and/or rear control arms. I recently bought a 3.2l conversion and am looking to get more tire on the ground at both ends but would prefer not to go widebody.
Thank you so much. :)
Travis Neff 04-15-2008 01:29 PM
Thank you so much. :)[/QUOTE]
Bada Bump! Would be interested in this too :D
Racerbvd 04-16-2008 10:51 AM
Bada Bump! Would be interested in this too :D[/QUOTE]
My 71 has this mod.
http://forums.pelicanparts.com/uploa...1208368213.jpg
Pretty simple, 2 pie shaped pieces added at each end & fender pulled out, lips rolled.
jtf914 04-16-2008 02:09 PM
Here's a thread on TRE Cup's fender mod:
http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/199699-getting-phat-914-6-a.html?highlight=951
Travis Neff 04-16-2008 02:10 PM
Giddyup! Thanks
racerx9146 05-01-2008 12:33 PM
Got 951 8 x 16's on the rear, 1/4 inch spacers, fits nice, 245/46/16 (not much tire vendor selection)
John Daron
http://forums.pelicanparts.com/uploa...1209670312.jpg
rfuerst911sc 05-01-2008 04:04 PM
John Daron
John nice looking car and thanks everyone for the feedback.SmileWavy
