-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Odd stall-out/failure to re-start (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/401802-odd-stall-out-failure-re-start.html)
markwemple 04-02-2008 12:43 PM
Took the '70/4 out to test the tranny and was about a mile up the road when it stalled out at a stop sign and failed to restart for about 3-4 minutes. I hadn't warmed it up so it was only running for about 5-6 minutes when this happened. Its a 1.7 stock config. Any ideas???
Tobra 04-02-2008 01:00 PM
maybe crap in tank/fuel filter, too quick for vapor lock.
How are your grounds?
markwemple 04-02-2008 01:04 PM
Fuel filter was replaced not too long ago, but the car does have a little old gas in it. Also, I put in some FI cleaner - Techron. The grounds should be OK but I am going to replace the ground strap at the tranny.
Mark Henry 04-02-2008 06:25 PM
Grounds and gas would be my guess as well.
Old gas can kill the valve guides in no time.
Varnish/crap can clog the brass in-tank screen, then float or settle away till the next time.
