Post Koni Front Struts
I have a pair of Koni Front Struts and they feel squishy, like most of oil has leaked out of them. The shaft can be pushed all the way in without rebounding. Can I add oil to these myself? Any help would be appreciated.
Old 10-13-2001, 06:27 AM
paulhagedorn's Avatar
Send a message via ICQ to paulhagedorn
Post
Don't know if you can add oil to them yourself, but I would think that would be kinda bad unless you can find the exact weight that was in the shocks.
Paul
Old 10-13-2001, 06:39 AM
Send a message via ICQ to oredith Send a message via Yahoo to oredith
Post
depends on the type of koni you have.. if the koni shock *isn't* externally adjustable (does it have a tab that you can turn on top of the shock?).. if not, it's a 'normal' koni shock, and won't come back up when it's depressed.. all it's doing is dampening..
Jeff
Old 10-13-2001, 08:44 AM
Post
Paul,
Im pretty sure they are the adjustable kind, although I am not sure how to adjust them. Here is a picture that might help:
Old 10-13-2001, 09:24 AM
bowlsby's Avatar
Post
Koni rebuild their shocks if you send yours to them. Check out their website for details.
I don't have the link from this computer but I think it is www.koni-na.com
Search for it if needed.
Old 10-13-2001, 10:20 AM
DDS DDS is offline
Post
Don't panic, they're just dampers, they don't rebound. If they're like my 911 units, you push them all the way in, then turn them to adjust - clockwise for greater damping. You can feel the adjustment mechanism engage when you do this and you should get 5 turns (IIRC) between stops. Try the damping (extend then compress them for the full length of their travel) at full CCW, then try again after having collapsed, and given the 5 turns (or whatever) CW. You WILL know if they're working.
I looked into rebuild, and they said it wasn't worth it for these relatively inexpensive units.
-- Dave
Pics of my '73 project here: http://members.tripod.com/mike4g/dds73_b4pics.htm
Old 10-13-2001, 07:46 PM
Post
the posted picture are definitely *not* the 'externally' adjustable konis.. if they were, there'd be little tabs sticking out the top of the shock (the bottom of the picture, in this case)
Old 10-14-2001, 01:18 AM
