Cant fire up my 914?
Hello
I have a 914 from 71, just bought from Sweden. But I have some trouble with my “new” 914. It’s a 1,7litrs who needs some welding, but the car is ok. I can’t start up the engine. The sparkplugs ignite perfect, there is gasoline in the tank, but it will not run. When I remove the fuel hose, and puts the hose in a bottle and starts the engine, I can’t see any fuel? Is it my fuel pump, where is the pump located? How does the fuel system work? Hope anyone is willing to help Best regards Jesper, Denmark
working in the garage
Welcome Jesper,
I'm going to tackle a non-running 914 later this summer, but found this site which might help: http://members.rennlist.com/pbanders/FPChecklist_frame.htm |
914 Geek
If you prefer a text article about troubleshooting the fuel pump control system, see:
http://web.archive.org/web/20021222030448/http://www.914fan.net/fuelpump.html --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thanks guys
![]() Where is the fuel pump placed? By the tank or in the engine compartment. A picture of my early911 Best regards Jesper, Denmark www.flat6.dk
In 71 it's in the engine compartment. Later years it was by the fuel tank.
914 Geek
From under the car, look up near where the right-side heater hose hooks up to the body of the car. The pump was originally in that area. If you don't find it anywhere near there (trace the fuel hoses to make sure), check up in the steering rack compartment. That is a popular place to re-locate the pump.
--DD
