Help! Part needed and/or advice
Don't all laugh at once, but I am in need of a section of the longitudinal from under the battery area. I purchased a project car that I thought was solid only to find out that the damage had been covered with fiberglass. I have been searching for a replacement piece without any luck. AA is the only place that sells a new piece which is way over priced and you never know what you are going to get from them. I am hoping that someone has this piece from a cut up car. Does anyone know where I might find this part or any advice on other ways to repair this?
Join rennlist....
www.rennlist.com Sign up for the 914-914/6 email lists. There are plenty of CA guys that have rollers that are being cut up. One guy has three sitting in a field in the desert.... Burr Patterson pitz@earthlink.net [This message has been edited by mikez (edited 10-21-2001).] |
We're all really just heavy metal people in the long run...
Try: http://www.docncys.com/ http://www.restoration-design.com/index1.html Good Luck Joe |
Also, Pelican does carry sheet metal. If you don't see the part listed in the on-line catalog, call 888/280-7799 and describe what you need. Chances are pretty decent that we can get it for you, and significantly cheaper than AA.
--DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
| All times are GMT -8. The time now is 11:24 AM. |
