My speedo won't hold accuracy I'm not sure if it is the cable or the tranny?
914 Geek
Probably the cable. The cable is also a lot cheaper and easier to replace than the tranny--or even the angle drive in the tranny.
I suggest replacing the cable first and seeing if that helps. --DD ------------------ Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Considering that 914's average approx. 23K+ years-old, chances are your speedo cable is:
Mine does the hypnotic bouncing from rest to around 25 MPH, but I can live with that; I'll get around to changing the cable. ------------------ Rouser! |
Mine started jumping before it totally went dead-the problem was at the gauge end of the cable. There is a crimped-on fitting that adapts the round (essentially a long spring) cable end to a square pin that drives the speedo. This fitting had come loose from the cable. I ended up replacing the cable-kind of a pain in the ass but not too bad, but I think JB Weld couldve fixed it too. I also had the elbow drive at the tranny go on another 914, but this just made the speedo die, no jumping around. I would pull the gauge out and play with it and the cable end first.
If you have a speedo repair shop handy, you can pull the inner cable and get a replacement for a fraction of the cost of a complete cable. As you pull the old inner cable out you can feel if there are kinks and tight spots. To lubricate the cable I used some teflon based oil and poured it in the front end of the cable with a small home made funnel till it ran out the back. I did this a couple of years ago and got a spare which I still haven't had to use. Good luck.
let me add an interesting twist/story to the angle drive comment above. i thought i was being smart when i bought an angle drive at a swap meet because mine had broken. put in the new (used) angle drive and the speedo still didn't work. ??? i thought to myself. then, when time permitted further musings, i trouble shot the system and observed that the new (used) angle drive turned the wrong way! i had bought a 911 angle drive which looks the same as a 914 angle drive but you can tell a 914 angle drive as the part number starts w/914.xxx.xxx.xx
