daddygo's Avatar
Electrical problem
Trying to help a friend who recently picked up a 73 914 with 1.7L
When the brakes are applied, or turn signal is actuated, the generator light comes on real bright. I'm assuming its a short, I'll find a wiring diagram, but if anyone has any suggestions, I'm all ears.
1973 911T Targa ROW
Old 08-25-2008, 05:25 PM
Always fun tracing those gremlins. Time to start cleaning up the wiring connections. I would start with the rear tail-light assemblies. Take the bulbs out, the assemblies apart, the connections loose.... Clean them all up well... Those parts are very problematic because they tend to get a lot of moisture. And the symptoms you described can be caused by corroded terminals in those areas. Wishful thinking on my part, but I hope that's all it is.
Old 08-25-2008, 08:04 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Check the fuses, too. They can pop and still look OK at first. Pull them out and brush the ends and the fuse holders with a wire brush to help them make good contact.
--DD
Old 08-25-2008, 09:05 PM
