Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Post 9 " X 15 RSR WHEELS ?
I convert my 914 to 916 look and I have 8" rear and 7" front fuchs wheels.
But I have space for more, Then I put one 8" in front and is ok !. (originally the 916 have 9 and 8 " )
Then I want 9" at the rear, I search on the books and I find that the carrera RSR have the 9" X 15 fuchs wheels at the rear.
And this particulat wheel maybe (I don´t know)have the deep offset or backspace that is apropiate for my car and I will don´t need spacers ?
Where I can find this wheels ?
Are this wheels ?, that was used in the 11 916 produced ?
Old 11-03-2001, 07:27 PM
Post
To clarify
The 916 came from factory with 4 7"X 15 but a lot of people that convert to 916 use the 9" rear.
The backspace change between the 9X15 and 9X16 ?
I want to know, where I can buy this wheels ?
Do somebody know how many 916 was produced, some says less than 20, other 11, ?
Old 11-04-2001, 01:42 AM
gruntie's Avatar
Post
1 x prototype & 10 x pre-production 916's produced, total 11. 9x15 fuchs are extremely rare & expensive, but copies are sometimes available. However 245/45x15 tyres are no longer available, & even with 225/50 the tyres rub on the inside lip of the wheelarch. 8x15 with 225/50 fit perfectly, 9x15 not worth the hassle.
Old 11-04-2001, 08:02 AM
Thumbs up
Thanks for your answer
What about 9 X 16 ?
What about 8" in all wheels ?
Old 11-04-2001, 10:09 AM
jabb's Avatar
Post
There are companies out ther that will make
steel wheels in any size or offset you want or need. I think Rennsport might offer this service. Just another option.
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 11-05-2001, 05:46 AM
RETIRED
Joe Bob's Avatar
Post
Why not space the wheel out using spacers? I can't imagine that you would be able to FIND a 15 inch tire much bigger than a 245 anymore...
Old 11-05-2001, 06:53 AM
Post
I don´t race, I only want the look of wider wheels. And only want Fuchs wheels.
Do somebody already have 9" in the rear of your 916 conversion ?
Old 11-05-2001, 07:06 AM
Post
Mr. Mike:
I already have spacers in my current wheels.
I want info about the bacspace in 9" X 15 and 9" X 16 fuchs wheels ?
Old 11-05-2001, 07:18 AM
RETIRED
Joe Bob's Avatar
Post
I don't have the imfo on 15 inch wheels....try the 911 list or rennlist.com email lists....
I can't believe that a 245 tire and a 8 inch wheel with 2 inch spacers won't fill the wheel well....that must be a W I D E fender flare.
BTW, big 15 inch tires are being phased out...so you might want to consider a Fuch faced three piece wheel. Most custom wheel guys can make you any width and offset you want....all ya need is money....
Old 11-05-2001, 07:39 AM
Post
Mr. Mike:
Ok, I´m wrong, I don´t undertsand very well your first post.
My flares are the normal 916 kit.
Forget anything and try again, this is my post.
In the beggining I use 4 7" cookie wheels (944) and my father make the spacers (I don´t remember at this moment the " ), Then came a friend with a 911 and I install 1 8" fuchs momentary in my 916 without spacer. and is ok at front but the rear maybe need a spacer or wider wheel.
My father have 8" bbs wheels in front of his 911 but this wheels have different offset.
I only want to know the backspace of the 9 x 15 and 9 X 16 FUCHS wheels.
This is my post
thanks
Old 11-05-2001, 08:11 AM
RETIRED
Joe Bob's Avatar
Post
Can't help you on the 9 inch Fuchs back space....there is a guy on the 911 list, Warren who will have that information. Try posting over there.
Not many 914s use a 9 inch wide wheel...8^)
Warren goes by the name of "Early S Man"
Old 11-05-2001, 08:14 AM
Post
Thanks Mr. Mike z
I receive an e-mail from wheelenhancement and they told me that the offset of the:
9 x 16 15 mm.
8 x 16 10.6 mm
9 x 15 ?
Old 11-05-2001, 08:25 AM
Scott S's Avatar
Post
I run 7's up front with a 1" spacer and 8's in the rear with a .25" spacer (factory fuchs). My flares are fiberglass and the lips have been trimmed back. But even so, there is no way I would have been able to fit a 9" wheel in there - and my car was one of the more "forgiving" 914's when it came to tires as I easily fit 205's on my four bolt fuchs prior to flaring. The 225 rear tires fit perfectly on an 8" wheel in terms of side wall bulge, etc.. I tried to jam a 245 up in there, but even after trimming the flare they would rub - and in my opinion looked way to oversized for the wheel. You can see the final result on my car in the Pelican gallery.
I thought the only factory wheel combination was 7" wheels on the 916, and that the GT and M-471 all came with 6" wheels and spacers. I thought anything else was something added by the owner. You can absolutely run 8" fronts - I did for a couple of years. My only reason for the change was I just love the vintage look.
-Scott S
Old 11-05-2001, 08:55 AM
Post
Mr. Scott:
Thanks for your good answer
Lamentably I can´t find your car in the gallery.
I supose that your wheels are 15 "
I can live with 8" in 4.
But I still want the 9", maybe If I buy the 9 wheels before I install the flares, I can make a little mod to adjust.
If you can send me a tail photo of you car I aprecciate alot.
thanks again
Old 11-05-2001, 09:37 AM
Stay away from my Member
campbellcj's Avatar
Cool
There is a black 914/6GT clone here in So Cal that was built by Hergesheimer and races with POC.
It has custom 3-piece wheels in back which I believe are 17x10's (maybe even 11's). They are built up on Fuchs centers with (I think) Kinesis forged rims. The guy is running 275/40x17 Kumho V700 tires in back.
These wheels are probably BIG bucks.
(Last I heard the car has been for sale. If I happen to come up with the money before it sells, I may actually buy it. Very sweet car.)
More pics of the car here (halfway down page): http://www.nosubstitute.org/events/SOW12May01
You could try contacting Laura or Mark at Hergeshiemer for more info. Their web site is: http://www.herg.net
Cheers,
Chris C.
73 914 2.0
70 911E Targa
campbell.chris@gte.net
Old 11-05-2001, 11:47 AM
Post
Wow ! I never saw 3 pieces fuchs
Mr. Scott I already see your car
1972 914 v6
1974 914 2180cc 916 Look
1984 944 Auto
550 spyder (replica)
My Page
Old 11-05-2001, 12:00 PM
gruntie's Avatar
Post
I have a pair of copy fuchs 9 x 15. The backspacing is 118mm with an overall rim width of 250mm, presumably the genuine item is similar. My 914 is a 916 rep with factory flared arches: the 9x15's with 225/50's (245/50's no longer made)rub on the inside lip of the arch, which would have to be removed virtually completely to get them to fit & would seriously weaken it. Someone leaning on it would probably bend it. Have since seen a genuine GT with 9's & the same problem.
So I use 8 x 15 with 225/50/15 all round, looks OK to me. Still have the 9 x 15 copies spare if anyone wants them!
Old 11-05-2001, 01:15 PM
Post
Gruntie,
Do you use spacers front or rear with the 8" Fuchs?
Thanks,
Mike
Old 11-06-2001, 10:02 AM
gruntie's Avatar
Post
Nope, just mounted directly to the hubs.
Old 11-06-2001, 01:45 PM
Thumbs up
Ok, thanks a lot to all for your answers.
I believe that the best solution for me is:
Have 4 8" X 15 " Fuchs with spacers of .25
Thanks and regards
Eduardo Castrejón Elbjorn.
Old 11-06-2001, 03:16 PM
