-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   what is the part number for a grant steering wheel? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/4364-what-part-number-grant-steering-wheel.html)
D-one 11-06-2001 05:55 PM
Any one use a Grant steering wheel, if so what is the part number for the adapter kit?
914GOD 11-07-2001 08:35 AM
Grant does not make an adapter kit that fits the 914/4. THey do make one that fits the 914/6.
I have heard rumors that some of the other adpater kits will work on the 4 but have had no luck finding one.
Here's what you can do...
Buy a wheel ( I like model 773, nice and cheap, good looking), and buy the 1" or 2" extension. The Grant part no on the 2" is #4000. You can then take your stock wheel apart and drill the rivets out of the hub. Depending on the year you then need to machine off some material from the front of the hub. Drill three holes for the 2" adapter and bolt it on. Your off to the races.
The 2" adapter works very well for me. The wheel in the 914 is set far too far forward for me at least, this makes it right.
Alternatively you can order a MOMO from GPR, they have great prices on them (like $109) of course you also need the $45 adapter and maybe the $50 spacer. The 2" Grant spacer will cost you $21.
Hope this helps!
Sean
