Architecture & Porsche's
New '73 914 owner, high idle issue
HI guys,
I've had 914's before, but been a LOOONG time. I just picked up this car to save my 911turbo & turbo928 from excessive miles: I think it has a 1.7 in it, but unsure...at least it's still fuel injected & runs pretty well.
2 things: it has a high idle, ~1600rpm or so: knowing more complicated EFI systems, Can I assume that I can just lower the set-screw on the throttle body to lower it, assuming I have good vacuum & hence, no vacuum leaks that are assisting with the higher idle?
Are there other things to look for with higher idle? Started the car after 4 days last night: idled at about 700 until it was warm, then was up to about 1600 again.
Thanks in advance, Mark
Porsche Club Racing National Scrutineer
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-19-2007, 07:46 AM
Control Group
Tobra's Avatar
It is likely you have a vacuum leak. Hoses can look good, and not be.
If it is a 1.7 or 2.0 it will be a D-jet. Change out the fuel hoses, you don't know how old they are, you might want to put the fuel pump in the front too, relatively straightforward and not a bad idea
Old 04-19-2007, 08:45 AM
The fuel pump is in front, so the hoses may have been replaced: calling the mechanic tomorrow to see what he's recently done to the car.
How do I tell what size the engine is & what EFI is on it? Thanks, will replace the vacuum lines this weekend.
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-19-2007, 08:51 AM
Hell Belcho
Nostril Cheese's Avatar
If it's a 2.0L, the throttle body will be on the top of the intake plenum and the air cleaner will be rectangular.
if it's a 1.7L, the throttle body will be on the side of the intake plenum and it will have a circular air filter.
another way to check is where the intake runners bolt to the head.
2.0L's use three studs, 1.7L's use four studs.
Old 04-19-2007, 11:28 AM
ah, the rectangular air box, I remember those now. I have a round one. D'oh!
'89 Andial 951
'82 928R
'74 911 RSR 3.6
Old 04-19-2007, 11:31 AM
Thumbs up sounds like...
Auxilary Air Regulator---as I understand it, is a big intentional vacuum leak to increase idle at cold start. constant 12v with key closes it within a couple mins, check voltage to it, then pull off hose when warm. If it doesnt restrict flow completely, it isn't working properly. I got one working again by boiling it and smacking it around. It wasn't available here last I looked.
If it is stuck closed the timing was probably advanced to compensate so that it would idle when cold. if so fix reg, retime and then adjust idle screw.
Old 01-04-2009, 01:43 AM
