'73 2.0 high idle
my '73 2.0 fuel injected 914 runs great but seems to have a higher than normal idle, around 1400 - 1800 rpm. is there a simple idle adjustment i can do or should i find a 914 FI specialist.
S
Old 04-03-2009, 11:02 AM
914 Geek
Check the timing, and check for vacuum leaks.
And there is an idle RPM adjustment screw in the left-rear of the throttle body. It's a bit tough to reach around the air cleaner, but it's there. Screw it in to lower the RPM, screw it out to raise the RPM.
--DD
Old 04-03-2009, 08:22 PM
