914 2.0 Pollution problem
Hello
I am a French user of an U.S. model 914 2.0 L Unfortunately my MOT comes out in May and my pollution is awful. No more Cold start injector, no injector leak, good fuel pressure, new Triad exhaust. Action on the button on the ECU makes nothing. But the motor start and run well ! I have no idea about this problem, perhaps fuel injectors don't spray very well ??? have you an idea, :confused: Thanks for your help. Sorry for my awful english language... I am best in french. Yves from Lille (North of France) |
What do you mean when you say the pollution is awful?
I also had trouble with the mixture control on the ECU not working. It turned out the switch was broken. The quickest fix was to install an ECU from another car, since they're not expensive. |
This is sort of the reverse of what we used to call "grey market" cars or ones from europe that came into America and were never correctly setup for the smog (your MOT) testing and then they finally get caught. The cars I have seen that required major work were required to have a catalytic converter installed plus any smog equipment that would also be from the car's original year of manufacture. I would suggest finding a shop that knows Porsches and has deal with American sold cars before and how to convert them to get them to pass your emissions test.
I want to say that the CO value is not good.
I don't know how much because I have no result but I think the value is more than 4 (under 1.5 for good result). In my workshop, I have no tool to control this CO, I don't think that a lot of person have one.... I don't know what to do, But I am going to see the switch on my ECU in a first time. Thanks for your help. Yves |
I believe that the specification for the correct amount of CO in the exhaust of the 1973-1974 2.0 engines is 3.0%. The 75-76 914s had more pollution control equipment on them (particularly the California-emissions models which had catalytic converters on them) and the specification for them was less.
Read through Brad Anders' D-jetronic website. That site contains almost everything that anyone knows about D-jetronic fuel injection. http://members.rennlist.com/pbanders --DD |
Horrible, yesterday I test my CO exhaust in a little garage near of my house...
Result 8.2 ... so last night I look everything on my injection and I unseal the manifold pressure sensor just to turn the 2 screws. I know that it is seal in factory, but I have no other solution. So, now, I am going again to test and unscrew inner screw... Results today for you and me. Have a good week end. Here in France weather not very nice ; lot of clouds, grey sky and low temp (10° C) Yves -- Lille France |
Pollution OK now
Wonderful,
This morning I went to a Technical Control Center (We call that in France) So I must use their Pollution control tools. I turn clockwise the inner screw in the Manifold Pressure Sensor and I saw my exhaust gazes OK !! about 1,5 turn in clokwise and all is all right. Now I have 1.2 CO before it was 8 and more... I drive to see if all is OK, Temp in use, start with hot motor temp, speed... Have a nice week. Sorry for my awful English language, I am best in French. Yves. |
| All times are GMT -8. The time now is 04:25 PM. |
