ASE Master Tech - 35 yrs
need to know how the 914 rear camber adjustment works - does the camber increase or decrease as you add or subtract shims?
Car is currently setup for track & I want to go toward street settings if i need to go more positive, would I add or subtract shims? the answer will determine if I need to buy more shims TIA
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
914 Geek
Remove shims for more negative camber. Add them for more positive camber.
The shims go above the outboard suspension pivot point, and below the chassis. So making the shims thicker moves the outer point down, tilting the top of the wheel outward. That's (in the direction of) positive camber. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
