ASE Master Tech - 35 yrs
larrym's Avatar
Question rear camber adjustment question
need to know how the 914 rear camber adjustment works - does the camber increase or decrease as you add or subtract shims?
Car is currently setup for track & I want to go toward street settings
if i need to go more positive, would I add or subtract shims?
the answer will determine if I need to buy more shims
TIA
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 05-30-2009, 11:17 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Remove shims for more negative camber. Add them for more positive camber.
The shims go above the outboard suspension pivot point, and below the chassis. So making the shims thicker moves the outer point down, tilting the top of the wheel outward. That's (in the direction of) positive camber.
--DD
Old 05-30-2009, 01:43 PM
