acar24's Avatar
turbo
I am working on a 914 with a turbo kit on it, I don't have any of the original paper work for it. It is all installed and working but I am trying to get the fuel mix adjusted so it runs better. Has any one ever seen one of these before/have any info? I know they sold this kit years ago, but I think fuel was a major problem. It has a turbo injector controller and 1 injector but it is not connected. I can get it to run fair up to about 3000rpm but then it seems to drop power. it was running pretty good but when I checked fuel pressure it was quite low - about 20 psi, but after raising it to specs, it is very rich and runs worse, Thinking I need to lower it and adjust the map sensor, any thoughts or info would be great. Thanks, LARRY
Old 06-12-2009, 07:53 AM
hasaramat's Avatar
Larry,
Some pics would be nice. I would like to see the set up. You could use a boost sensing fuel pressure regulator. They have them from 1 to 1 all the way to 4 to one. It will keep the pressure low until the boost comes up. That extra injector is probably needed for fuel under boost
1999 Boxster
1980 911 SC Targa
1974 914-6 GT endurace race car
72 911 RSR clone (needs full restoration)
Old 06-14-2009, 07:50 PM
Unregistered
sammyg2's Avatar
Sounds almost like an old crown turbo system.
More details would help.
Old 06-20-2009, 01:58 AM
