-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 strut inserts work with 911 struts (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/506118-914-strut-inserts-work-911-struts.html)
w21055 10-20-2009 06:06 PM
Hey guys. I want to ask before I start tearing the car apart.
I bought a 84 Carrera front end for my 74 914. The strut inserts from the 911 are pretty much shot so I wanted to know if I could put the inserts out of my 914 struts in the Carrera struts since they are fairly new. I searched and ran across answers from no to yes or yes depending if you can get the right nut (don't recall exact name) Flange nut I think.
Phillip
tat2dphreak 10-21-2009 08:31 AM
on the early(70-73) boge struts you can use any 914 strut insert, but on the later struts, you have to use the 911 they were designed for as far as I know... bilstein inserts for bilstein struts, koni for koni. boge uses any
w21055 10-21-2009 05:28 PM
Ok thanks. Was hoping for the cheap way out, I thought 914's were cheap :^).
tat2dphreak 10-21-2009 08:22 PM
they are, you are using a 911 part tho ;)
