914-6 weber setup
Whats the best way to setup Weber's on a 914-6? Series or Parallel? Single fuel line from the tank or a return line? Pressure from fuel pump? Sorry to just spit some stuff out but these are thoughts running around in my head
Old 01-10-2010, 11:51 AM
Webers
My 2.2 S motor w/webers has one line from a low pressure electric pump (don't use a pump for an EFI system...too much pressure...30+ psi) with an in-line filter and pressure regulator as a precaution to prevent flooding. If I recall correctly it is set at 3 or 4 psi. The single line is split to each bank of carbs and I've never had any flooding or fuel starvation problems. Hope this helps.
Old 01-12-2010, 08:50 AM
great help
Old 01-12-2010, 07:21 PM
JW Apostate
trekkor's Avatar
I use a Holley red fuel pump with a Holley one-in-two-out fuel pressure regulator.
The regulator is like a tee.
No return line.
Fantastic!
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 01-13-2010, 11:34 PM
any idea the model nuber on that holly regulator?
Old 01-15-2010, 05:42 PM
John Rogers's Avatar
The setup I had was like Trekkor's except I used one of those huge aluminum canned filters from a Porsche 930 just before the regulator. I looped a fuel line between the carbs with a pressure gauge mainly since they came setup that way.
Old 01-15-2010, 06:47 PM
Stay away from my Member
campbellcj's Avatar
I guess my setup is also similar to those described above. Holley Red pump and big Canton filter up front; metal line through tunnel; AN-6 from firewall to a regulator with gauge. There is also a small inline filter right before the regulator. I use the PMO fuel bars and added the second line between the carbs. No return line to the tank. This has worked very well.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 01-17-2010, 10:38 PM
