Fuse Locations
I am in need of the proper fuse locations in the under dash fuse box from left to right. I cannot find it in the Hanes manual and I have searched this board with no luck. Some idiot at the paint shop broke my cover and kicked half the fuses out. Thank you in advance.
Chrome yellow on a teener looks SAHWEET! |
. . . from my '76 owners manual, 12 fuses, left to right
8 amp, left headlight high beam 8 amp, right headlight high beam 8 amp, left headlight low beam 8 amp, right headlight low beam 8 amp, left parking light 8 amp, right parking light 8 amp, license plate lights 16 amp, windshield wipers,cigarette lighter, turn signals, stop and reverse lights 8 amp, fan, horn 16 amp, (optional) fog lights 8 amp, emergency flasher, interior lights 16 amp, retractable headlights additionally: a 25 amp fuse for the heater blower, fuel pump and rear window defogger is located on the RELAY PLATE mounted on the left side of the engine compartment. If the rear window defogger is not installed, a 16 amp fuse is used. Last edited by type47fan; 11-20-2001 at 10:14 PM.. |
Here's the pelican web page that has a diagram for the fuse locations: http://www.pelicanparts.com/914/technical_specs/914_electrical_fuses.htm
hope the link works.
Xerxez 73 914 2.0L Sunflower Yellow/Blk/Blk 70 914-6 White/Blk/Blk |
THANKYOU
You guys are awsome thanks alot. Enjoy your holiday.
