fuel system question
I have a 1973 914 1.7... the fuel pump is bad and the line are bad and i am replaceing all of that but i was wondering since my car is fuel injected would it be best to leave it the way it is or switch to carbs...
Old 02-20-2010, 07:49 PM
Resident Electrician
Mike Bellis's Avatar
On a stock engine, factory will run better and be more drivable. If your engine is modified, Carbs may have better performance.
It is really a personal choice. If you want to go high tech, invest in a modern EFI system to replace the factory FI. EFI will run better than both and give better performance and economy.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 02-20-2010, 08:22 PM
racer's Avatar
x2 on personal choice. There is nothing wrong with the fuel injection system. It just requires that all the vacumn lines be checked as leaks will cause running problems. Swap out those fuel lines in the tunnel and in the engine compartment.. don't forget the injector elbow either.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 02-22-2010, 05:18 PM
