Need help on installing rear sway bar drop links.
Hey, I just got some drop links and bushings for my rear sway bar on a 75 1.7, Im having one heck of a time putting them on though, does anyone know of a good way to pry them on? And at the same time, would it be better to have the bushings on the joints of the sway bar and strut first or the links themselves?
Any ideas, past experiences etc would be appreciated!
Thanks!
Old 03-28-2010, 08:47 AM
Control Group
Tobra's Avatar
I put them on the end links first, dropped in HOT water for a few minutes to soften them, vise with small screwdriver to get them going. Rubber mallet to pop it on to the end of the shock, C clamp to get it on the end of the sway bar
Old 03-28-2010, 09:09 AM
Ok, Ill try this.
Thanks!
Old 03-28-2010, 11:41 AM
SirAndy's Avatar
I usually add some grease and drill a tiny hole in the back.
The reason why they don't go together easy is because of the air trapped inside when you try to insert the swaybar into the bushing.
If you give the air a way to escape, the bar slides right into the bushing with little effort.
Andy
>> 1970, 914-6, 3.6L (Conversion)
>> 1970, 914-6, #374 (Original)
>> 1975/73, 914 Limo (Custom)
Old 03-28-2010, 11:51 AM
Ok, will do that too.
Thanks!
Old 03-28-2010, 02:35 PM
Send a message via AIM to mikelsr Send a message via Yahoo to mikelsr
I just replaced mine on Friday. I thought about the grease but didn't use it. Wish I had thought about the hole. I ended up using a big set of channel locks to get them on. Thanks Andy.
Old 03-28-2010, 06:20 PM
Yeah, Ill probably do all of it (hot water and putting holes in them sound most promising) and see what I can achieve from that.
Old 03-28-2010, 06:50 PM
bushings
Ok, so I used hot water and put holes in the back, they went in so it worked. Thanks for the help!
1975 Porsche 914/4-1.7
1990 Mazda Miata 1.6
(And some Vespas)
Old 03-31-2010, 05:46 PM
