How do I install a Mallory Distributor
This might be a totally basic question so please excuse me for being an idiot.
I bought a Mallory distributor (#4554101). I read on these forums that this is the ideal distributor to use. My car currently has a .009 distributor.
My question is - how do I install it? My .009 distributor has one wire coming out of it. The Mallory has 3. The wiring procedure acording to the instructions are:
Red Wire: If you use loom resistance wire, connect to the coil (+) terminal. If you use a ballast resistor, connect to 12 volt side of ballast resistor. Huh?
Green Wire: Connect to coil(-) terminal. Ok. That seems simple enough
Brown Wire: Connect to engine block ground. Also seems simple enough.
I think the big question mark to me is that darned red wire....
Thank you for your help.
Marc
Old 05-11-2010, 10:03 AM
The Red wire is your switched (on/off by ignition switch) power for the distributor. I'm running mine through an MSD, so I'm not sure about those wire colors; but I'm pretty sure about the Red wire being the 12v source for the dizzy. Did you swap springs and set the advance curve? Mike
Old 05-12-2010, 07:42 AM
Kirmizi - Thank you for the reply. I have not installed the distributor yet. So, does the red wire go to the positive of the coil?
To answer your other question, I have not swapped the springs nor have I set the advance curve. I'm not quite 100% on how to set the advance curve but I'm ready to learn.
Old 05-12-2010, 08:17 AM
According to the wiring diagram, yes. Like I said, I'm running an MSD box so my dizzy lead is from there. I installed the Mallory Advance Curve Change Kit (different springs) in mine, the grey+grey springs I believe. The kit provides the springs and tools to set the advance. Mike
Old 05-12-2010, 10:21 AM
Wire it just like the diagram. Brown is ground. red 12V switched power and green to the coil negative.
Be careful about what coil you use. some need a ballast resistor. FLAPS always have them.
Oh and you will have to dent your cylinder tin a little bit to get the cap to fit. No biggy.
Old 05-13-2010, 03:07 AM
Joe - thank you for your insight. I am using a Bosch coil. I assume I will need a ballast resister. I will be installing it today. I'll let you know how it turns out.
Old 05-13-2010, 07:34 AM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The stock-replacement Bosch coils (and the original ones) effectively have the resistor built in. Some of the aftermarket ones, particularly the "high performance" coils, do not.
--DD
Old 05-14-2010, 10:00 AM
