Weird flywheel question...
While cleaning up my shop I unearthed a flywheel that is in very good shape. My problem is that I have had so many old cars over the last 45 years I cannot remember what this came off of.
But I do think it came off a 1972 914 1.8. But how can I tell?
I can measure it, but from where to where? The diameter is supposed to be 215 mm, but is that OD or from side to side excluding the teeth?
Where, if anywhere, is the part number located. I cannot find one anywhere.
I would be grateful for any help.
Thanks.
Old 07-23-2010, 08:40 PM
Type 4 Unleashed's Avatar
The 215 mm indicates the clutch disk size, the clutch disk area of the flywheel will be slightly larger. And all the Type lV 914 motors have the same flywheel.
Richard
Old 07-31-2010, 02:41 PM
Thanks! This is very helpful information.
I am still looking for a part number; hopefully one will surface after I run this through the bath as it is covered with dust from clutch wear.
But at least I have somewhere to start from.
Old 08-02-2010, 11:15 AM
