-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Differences EA (W) and EB-Engine? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/555451-differences-ea-w-eb-engine.html)
phulc 07-27-2010 03:19 AM
Hi Gents,
I recently purchased by "mistake" a EB-Engine for my 181 thing. I was told it to be the US-Version of the 1.7 80hp W-engine, but now I learned, that EB is the Californian Version with lower compression and 72hp.
My questions are:
  • What are the differences between EA and EB?
  • How is the lower compression achieved?
  • Can I easily rise rompression or make the EB work like a EA?
I´d like to use the engine as it is, i.e. a 1.7 with fuel injection, but the EA has more torque and thus makes more fun, I assume ...
These are the specs I found:
W, EA: 8,2 : 1
EB: 7,3 : 1
W, EA: 132 NM bei 2700 U/min
EB: 121 NM bei 2700 U/min
W, EA: 59 kW (80 PS) / 4900
EB: 53 kW (72 PS) / 5000
Thanks in advance.
FF
http://www.181-berlin.de/images/stor...0_dscf6546.jpg
SirAndy 07-27-2010 03:10 PM
No clue on the actual differences, but i like your Kübelwagen!
SmileWavy Andy
racer 07-27-2010 03:17 PM
I think its different shapped piston domes. I know on the 2.0l motors, the difference in compression is a function of the flat domed (euro) piston vs the american ones that have a recess on the top.
it would make sense that the US (California) spec cars used different motors to meet more stringent emission needs. Lower compression was a good start.
http://www.pelicanparts.com/914/914QA/914Q_euro_vs_usa.htm
http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_ENGpis_pg1.htm#item2
I thought the "thing/181" didn't use a type IV motor..
Dave at Pelican Parts 07-27-2010 10:33 PM
You can swap a Type IV in to a Thing; some have taken to calling that a "481".
I'm guessing the pistons are the difference, but I don't know for certain either.
--DD
Bleyseng 08-04-2010 11:36 AM
yes, the difference is in the pistons as the W and EA had domed pistons while the EB had dished pistons.......
I would check the pistons or just run it as it doesn't make that much difference and the Djet FI be nice in the Thing
