Exclamation 914 powered 356 ?
Anyone done a 356 outlaw upgrade using a 914 as the power plant
What is required ?
Target car is an open "A"
Especially interested in those where a High Power 914 (>2.2L) was used with a 741 or 901 trans
I know about the Flywheel <200mm for a 741
What running gear was used ?
Best Gear Ratios?
What Brakes / Suspension Mods are needed?
What Trans/Engine mount Mods needed to handle the extra torque?
Would really value the advice
Cheers
Higg
Old 01-10-2002, 12:26 AM
This isn't much, but several years ago Excellence magazine did an article about a 356 that had been prepared for the current historic version of the Pan American Rally. (Is that the correct name?) The car was beautifully done and they used a type 4 for durability and torque. It may help if you could find a copy of that article.
Mike
Old 01-10-2002, 05:58 AM
