911 to 914-6 engine oil cooler
Although when installing a six into a 914 I have always used a 914-6 engine oil cooler I assume that one could modify a 911 engine oil cooler when fitting a six into a 914 chassis. Does anyone have any experience with such an approach?
Old 02-15-2011, 07:08 PM
The 9 Store
Rich Johnson modifies 911 coolers. a914guy@aol.com Great guy!
Old 02-16-2011, 05:30 AM
914 Geek
Yup, he does and he is. The general idea is to cut off the outlet (inlet?) that interferes with the suspension pickup point, and weld a 90-degree fitting on in its place. I don't think there is room to screw a 90-degree fitting directly to the existing straight-out one, so you pretty much have to cut and weld.
--DD
Old 02-16-2011, 02:57 PM
Send a message via AIM to jim912928
I just had Rich convert my 3.2l oil cooler for a 914-6 conversion...unbelievable job...it looks much better then orginal equipment! Have Rich do it!
Jim
80 911SC Targa
75 914-6 3.2l Conversion
58 Triumph TR3A
07 Harley Night Rod Special, 08 buell 1125R, 08 Harley CVO Springer, 09 Harley Iron
Old 02-17-2011, 09:31 PM
rfuerst911sc's Avatar
Rich converted mine for the 3.0 he did a great job. And he makes/sells other items for a /6 conversion like the throttle linkage, engine mount etc. and all are top quality and fairly priced. And he's a top notch guy to deal with.
Old 02-18-2011, 04:23 AM
ASE Master Tech - 35 yrs
larrym's Avatar
Otto's in Venice also does the cooler conversion - i have been running one for about 1o yrs after my oem cooler developed an internal leak
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-26-2011, 10:47 AM
