Heat to my feet
I finally reconnected the heater ducts, flapper boxes and control wires and the blower fan in the engine bay.
Now I can get some heat to the screen defrost but no heat to my feet?
When I put the fresh air blower on, the lever to control air up and down seems to work as the arrows indicate but it does not work to direct the hot air from the engine to my feet. Is this correct?
I think the cabling function for the heater switch boxes must be confused? Does anybody have a plan / description / diagram of how it should be in a 73 - 2.0?
Old 01-30-2002, 05:55 AM
philinjax's Avatar
Pages 207 and 208 of the Haynes manual gives a pretty good
explanation with diagram.
Phil
Old 01-30-2002, 06:31 AM
914 Geek
So does the 914 FAQ elsewhere on this site.
Briefly, use the red lever on the air controls on the dashboard (the lower lever, I think) to direct the warm air up or down.
--DD
Old 01-30-2002, 09:54 AM
it is simple top levers left for heat bottom lever controls where it goes ... to the right is windsheild left is feet
i get almost no heat to feet on my car till i modified the heat system
se my post free heat up grade it can make all the differnce it did in my car but when you do my upgrade it reverses the controls
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 01-30-2002, 07:49 PM
