newbie 1.7 question(s)
Guys, I've been lurking for a while and I'm considering the purchase of a '72 914. I'm definately new to the aircooled stuff so please bare with me. It seems like a good deal, $500 with a little rust and has been sitting up for about 6 years. He has replaced the tail shift with a side shift and at some point re-sleeved (if that's the proper term) the 1.7 to a 1.9 and has a single 2-barrel carb. He said it ran before storage and he thinks it still will.
My question is what to expect if the engine needs work? . How much should a basic rebuild cost? I looked into the Raby kits (very sweet) but way outta the $$$ range. Can I expect to get it back up and working for $1500? Can I squeeze a little more power out of it while I'm at it? I appreciate any help or advice. I'm trying to get the car up and running, in good shape for between $3k and $4k and if not, will simply pass it up. TIA -tommy |
I've never seen a $500 914, so I don't know what to say about your find. Since you (or the owner) didn't say why it was laid-up for near 6 years (?), I have to assume it's for something you (or the owner) will have to fix to get it running/driveable. If it's (now) a 1.9L, than the owner installed a big-bore kit (larger pistons & cylinders). It's not usually the incidentals that'll eat up your $1,500 budget, it's the accidentals:
A Few Incidentals
Rouser! |
Instead of getting it up and running for $3-$4k, buy one for the same price. If you can't spend it all now, wait until you can.
In my experience, what looks like $4,000 to rebuild is more like $8k when you are done. Or at least start with something that is road worthy now. I have seen decent 914's for $1500 that would be good starting points for a project. Unless you really want to do it for the joy of it.
Randy Foulds, La Quinta, CA |
