Where to find CV bolt tool?
Anybody know where I can find a CV joint bolt driver? What is it technically called? It has 12 points, right? I seem to only find Torx-type drivers, and they have 6 points, I believe.
Thanks,
Ray 76 911S Targa Continental Orange |
Ray,
I am sure that there are local sources, however I purchased one from Performance Products. Not sure if PP carries them. Good Luck Bob
923/912E (2.1l OEM EFI '99 F150 4x4 Chipped (who cares) LLVL in the LBC... "Long Hoods Rule" "RICE - The Breakfast of Champions" |
Pelican has them as does most bug shops:
Use our removal tool to easily remove those pesky CV joint bolts. Avoid stripping your bolts, and spending wasted hours of cutting and grinding stripped bolts. 8mm tool for 12-point 'star-type' bolts. CV Joint Removal Tool, 12 point, 8mm Here is the link: http://www.pelicanparts.com/catalog/shopcart/9144/POR_9144_suspen_pg3.htm#item14
'73 914, 1.7, with Boxster transmission in the future?
914 Geek
Thanks, Mike.
These are "triple square" bits, and ordinary Allen bits will usually just strip them out. Get the right tool for the job. Snap-On sells them, if you're lucky enough to have a truck stop by you. Many VW Bug shops also sell them--just ask for the "CV Joint Socket"; they should know what that means. They and thhe 911 also use these same funky bolts. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
