Buzzing Passenger door
i had to fiddle with the relay under the paaesnger seat to get the car to start. Now when i open the passenger door with the ignition off, the buzzer unger the seat goes off. any ideas.? The interior light does work when the drivers side door is opened.
Old 04-23-1999, 01:49 PM
914 Geek
You must have a 74. The first relay you messed with is the infamous "seatbelt interlock relay". It is supposed to keep you from starting the car unless your seatbelt is fastened. Unplugging the wires from the seatbelt buckle disarms it, but it can still fail and keep the car from starting.
If you want to permanently remove it, just splice the two fat yellow wires (one may have a red stripe) together. Then you can get rid of the relay.
Three methods of splicing. Make a jumper that fits in place of the relay. This still allows water and corrosion in, but it is simple and easily reversible.
Cut the wires and use a crimp connector. This does somewhat better at avoiding corrosion, but is still relatively simple.
Cut the wires, solder them together, then shrink-wrap the connection. Best water-exclusion and corrosion resistance, but you have to be able to solder and have the equipment.
The buzzing under the seat is the "door is ajar" buzzer. It's perfectly normal. If you want to get rid of it (I certainly did!) just unplug the smaller of the two "cans" under the seat.
--DD
Old 04-26-1999, 11:29 AM
