914 1973 1.7 l fuel pump
i just purchased a 1973 914 with 1.7L engine L fuel injection. I am not getting 12 volts to my fuel pump.not sure why?
Old 06-13-2011, 01:16 PM
914 1973 1.7 l
does the the fuel delivery pump relay make a noise or click when the car is powered up?
Old 06-13-2011, 01:33 PM
914 Geek
A stock system has the fuel pump powered by the fuel injection system. It runs the pump for about 1.5 seconds when you turn the key from "off" to "on", then it stops until you crank the starter.
The pump circuit does sometimes get re-wired by people who don't completely understand it. Or by those who convert over to carbs.
--DD
Old 06-13-2011, 03:14 PM
yes it clicks
Old 06-13-2011, 03:18 PM
hardflex's Avatar
Check the fuse on the panel in the engine compartment. Mine corroded and wasn't getting power thru it
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 06-13-2011, 03:19 PM
Dave,
how do I check whether the fuel injection system is powering the fuel pump?
thanks
Old 06-13-2011, 03:23 PM
fuse ok
Old 06-13-2011, 03:24 PM
