Embarrassed to ask but...
I need to know and can't find answer in any of my books.
Where exactly are the oil pressure sending unit and the temp.
sensor II ('75 1.8 L-jet)? My oil pressure light is not working (haven't checked the bulb yet) and I also want to check the temp. sensor. There is one sender next to the distributor, must be one of the two. Which is it? Where is the other one?
Old 03-10-2002, 11:11 AM
Zeke's Avatar
Jim, do a search on sensors as this was discussed recently. Pressure on top, temp on bottom of engine under oil fill/breather tower. The temp sensor is behind the first blank plate. You need to drain the oil before removing the plate(s).
Old 03-10-2002, 06:00 PM
Guess I wasn't clear in my first post. It is the fuel injection head temp sensor I was trying to find. Paid a visit to JP Stein this am.
He solved my problem. Oil pressure by distributor, head temp.
out of sight under #3 manifold runner, entering tin horizonatally.
Old 03-10-2002, 06:16 PM
