Distributor O-ring
A picture is worth 1000 words.....
What do I do? thanks
Old 11-04-2011, 04:30 PM
the original seal will usually be dry and hard take a small pocket screwdriver and lever out old dry brittle o-ring it will break and lube with oil the new o-ring and gentley work it over the gear and shaft and install in the distributor shaft housing groove with the flat side of o-ring towards the housing groove and the round part of the o-ring towards the outside. lube housing and o-ring and install in engine. regards tom
Old 11-04-2011, 06:18 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
A replaces B.
B is what happens to the seal after being in an engine for 30 odd years.
You will need to cut B to get it off the distributor shaft.
Old 11-09-2011, 07:17 AM
