-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914-6 oil lines where to run them (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/63993-914-6-oil-lines-where-run-them.html)
mepstein 10-19-2017 01:38 PM
Originally Posted by totle (Post 9779317)
any pictures of running the oil lines in the inner fender like on the 911?
See that this is the way ERP solves it.
ANyone has i DIY picture with braided lines ?
What AN is used on the lines? AN-12 , or is this too small ?
I run A/N 12 lines up the reinforcement brackets on the longs and up over the wheel wells. Pressure up the passenger side and the return line down the drover side. Takes very few holes in the metal to make it work. Took out the rubber plugs in the front panel and the two metal plugs in the floor that are glued in with seam sealer. Engine is a 3.2
