914 Distributer
I have a 74 914 2.0 and just changed the cap, rotor, Points and wires. The car starts fine but has no power. It runs without back firing but wont rev above 3000 rpm. I do not know where to start and would appreciate any help.
Old 01-13-2012, 08:41 PM
914 Geek
Double-check the dwell angle and the timing.
--DD
Old 01-13-2012, 10:32 PM
Do you have a technical article on how to do that?
Old 01-13-2012, 11:19 PM
Never mind found it
Old 01-13-2012, 11:22 PM
Okay so this morning I adjusted the dwell by ear (if that is possible) and for the most part the car ran really well, but later in the day is started giving me trouble; Sputtering and no power so I bout a meter and tested the Dwell. It was at 34. I adjusted it to 47.9 and checked that it did not deviate +- 1 degree at 2000 rpm. Took it for a drive and it had no power. Then I tool it down to 44.5 and drove it again - still no power. So finally, I adjusted it to 34 and it runs well enough to take it to a shop, which I was trying to avoid) but nonetheless I am stumped. I made sure the connections were correct and the settings on the meter were correct. Any final suggestions would be greatly appreciated.
Old 01-15-2012, 06:00 PM
914 Geek
Any time you change the dwell, you change the timing. You have to re-time the ignition after adjusting the dwell.
--DD
Old 01-15-2012, 08:56 PM
Control Group
Tobra's Avatar
May have knocked some vacuum lines loose too, check those
Old 01-16-2012, 12:07 PM
You may want to double check your ignition wires. You can reverse them and the car still starts okay but you won't have the power.
Keith
Old 01-16-2012, 09:14 PM
Keith
Yea what he said
4-3-1-2
and if you don't have any clue what you are doing the shop is the best place to fix it. before you completely ruin a motor.
Old 01-17-2012, 12:00 PM
