-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Stuck front lid help (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/658426-stuck-front-lid-help.html)
wndsnd 02-15-2012 05:03 PM
Any suggestions on how to get front lid open that is stuck?
Once again thanks for any help. SmileWavy
esses62 02-15-2012 07:20 PM
front trunk? try re-seating the trunk release pull. have someone press down on the front hood while you pull release. If that doesn't work you can remove the front bumper and use the emergency trunk lock release. Turn the steering wheel to full lock. Stick your hand inside the wheel wells towards the front turn signals. There should be two 13mm bolts that hold the bumper on. remove them. turn the wheel full lock in the opposite direction and do the same on the other side. Once the bumper is off you will see an access hole near the center of the hood where the lock mechanism is. Insert a thin screw driver to release the lock. Voila!
wndsnd 02-16-2012 03:41 AM
Thats the expertise I am lookimg for! Thank You!
