wndsnd's Avatar
Stuck front lid help
Any suggestions on how to get front lid open that is stuck?
Once again thanks for any help.
1973 914-6 Conversion
2.7, crank fired, twin plug.
2006 997.1 Carrera S Cabriolet
Old 02-15-2012, 05:03 PM
esses62's Avatar
front trunk? try re-seating the trunk release pull. have someone press down on the front hood while you pull release. If that doesn't work you can remove the front bumper and use the emergency trunk lock release. Turn the steering wheel to full lock. Stick your hand inside the wheel wells towards the front turn signals. There should be two 13mm bolts that hold the bumper on. remove them. turn the wheel full lock in the opposite direction and do the same on the other side. Once the bumper is off you will see an access hole near the center of the hood where the lock mechanism is. Insert a thin screw driver to release the lock. Voila!
Scott
88 911 G50 3.2 Targa Signal Red DP935 NA
95 993 C2 Coupe Black/Black
99 996 C2 Silver/Blue
77 911S GP White/Cork
Old 02-15-2012, 07:20 PM
wndsnd's Avatar
Thats the expertise I am lookimg for! Thank You!
Old 02-16-2012, 03:41 AM
