Sender for combo guage
Just picked up a combo guage (fuel & temp) and need to find out which sender will work with it. The new VDO does not as I tested it and the needle barely moves. Pelican shows on but it's not clear if it is the right one for this guage.
I am sure that the stock temp sender mounted on the front bottom of the engine case will work with your fuel and temp combo gauge.
Phil |
This is an older car and does not have a temp sender. I added one to my '74 which mounted on the oil pan (apparently that's what it's called) on the bottom of the engine. Unfortunatly this one only works with a new VDO guage. What I need to find out is what part to order for the older gauge.
The stock oil temp sender Porsche part number is 039 919 268 .
I don't know if this part is any longer available. If not, you might find one from the many people parting out cars. Phil |
Just ordered stock sender from Pelican-$26.00.
Sender $26 what about the mounting plate?
Jim (and everyone else),
That's great that PP has the stock sender in stock for $26. Does anybody have any of the special two piece mounting plates or can you just thread the existing plate and still get "accurate" readings? |
