-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Basic Tune Up Question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/673861-basic-tune-up-question.html)
Highland 04-24-2012 06:09 PM
I just have a couple of simple tune up questions:
1) I have a 1.7L. Can I replace the ignition cables with the 2.0 from Pelican Parts or will they be too long? The comment on the 1.7 ignition cables are that they are too short.
2) The PO installed electronic ignition which works great. I notice it has a rev limiting rotor. Do I have to replace it with a rev limiting rotor and can I use a normal rotor.
Thanks guys and gals.
Tobra 04-24-2012 06:11 PM
the rotor for the electronic ignition may be necessary for it to work
don't know about the plug wires being too short, you may just not have them hooked up correctly
URY914 04-24-2012 06:54 PM
Yes your wires maybe too short. The plugs are located differently in a 1.7 and a 2.0.
If it is a stock dizzy the standard rotor will work fine.
Dave at Pelican Parts 04-24-2012 09:25 PM
You can use 2.0 wires on a 1.7; the extra length will not hurt anything.
You should be able to replace the rev-limiting rotor with a plain one, but you will lose the rev-limiting feature. This may be a good or bad thing as far as you're concerned. ;)
--DD
