hard top bracket
I need to replace the hard top storage brackets. They appear to be pressed on with a rivet of some sort. Do they just need to be drilled out and replaced with a nut and bolt or is there a different way to remove the rivet
Old 04-28-2012, 03:07 PM
914 Geek
The white plastic brackets at the front? Drill out the rivet and replace with a nut and bolt. On my car, those are bolted in, and there is a weld-nut in the trunk wall. I don't remember if there were specific years where they were riveted in.
Can you post a picture, and more information about your car?
--DD
Old 04-28-2012, 03:42 PM
BobbyQ's Avatar
Mine were bolted - '74 2.0
Old 04-28-2012, 04:17 PM
Yes, mine are the white plastic ones. I will drill them out. Thanks for you help
Old 04-28-2012, 05:31 PM
Resident Electrician
Mike Bellis's Avatar
Mine are bolted too. No rivets, 1973
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 04-29-2012, 12:51 PM
Scrappy's Avatar
'75 - '76 cars ... were riveted.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 04-30-2012, 05:52 AM
