-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   How to remove heater control box/blowers? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/681216-how-remove-heater-control-box-blowers.html)
Hogger 06-01-2012 01:30 PM
The Haynes book is a little vague about the actual removal of these parts.
I've got the fuel tank out, all the ducting hoses are removed, and control cables are loose. I have also removed the bolts from inside the cabin, on the top of the firewall that holds the "boxes" in place.
They are loose, and I can move them a little, but just not quite enough to pop them out.
Do I have to remove the dash so the defrost vents can have more room to move?
Is there something else I'm missing?
monkeyboy04 06-01-2012 01:41 PM
IIRC there are two bolts on the sides too. Those have to come out.
It's a bear to remove. That I remember vividly.
Hogger 06-01-2012 04:59 PM
Got it, thanks.
I missed a couple spring clips on the front and back of the units.
