neilca's Avatar
Front Brake Rotors
I was looking for new brake rotors for my 1975 914-4. I see listings for early and late rotors. What is the difference between the two? Sure is a price difference.
Thanks,
neilca
Old 06-09-2012, 07:07 AM
Travis Neff's Avatar
Late rotors are hubcentric, early are not. I believe the rotor offset to the hat is a little different between the two. You can't interchanges without changing strut/caliper
Old 06-09-2012, 02:56 PM
neilca's Avatar
I was trying to fit some 16" Fuchs on top my late rotors but the center, hub centic part, was too big for the Fuchs. I guess I will have to machine these rotors to fit.
neilca
Old 06-10-2012, 06:10 AM
racer's Avatar
911 fuchs are 5-bolt. 911 fuchs were 14,15 or 16"
914 fuchs are 4-bolt. 914 fuchs were only 15"
Need more info about your brake/suspension set up as the car in the avatar looks pretty "non stock"
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-13-2012, 04:30 PM
neilca's Avatar
This is not for the race car. I have a street 1975 that I am fixing up. What I am doing is putting 16" Fuchs onto the stock 914 rotors. I will be drilling them for the 5 lugs. I was hoping the early rotors could be used since they are not the hub centric type. The feature that makes them hub centric is too large for the Fuchs.
I looked at using the 911 components but I want to keep the ones I have as spares for the race car, you never know...
Old 06-14-2012, 03:10 AM
PMB Performance
Eric_Shea's Avatar
You need to machine off the hub-centric ring. Here's a picture of that exact mod. You can't use the early because the offset is way different.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 06-23-2012, 02:33 PM
