Question 914 charging problems
I think I already know the answer but before I go through the work to replace the alternator I would like to confirm my findings.
I have gone through the troubleshooting steps from the tech info and these are the results.
When I apply battery to DF the alternator starts putting out 13.8v and remains there when I remove the battery. If I short D+ and DF the Alt. light remains on. Last there is a 6v difference between B+ and D+ (not sure that means much but if I read right the difference should be 0v).
Oh yea I have not replaced the bulb for the Alt. light but that doesn't mean someone else hasn't.
Old 07-28-2012, 02:00 PM
PS How do you tell the wattage the bulb for the Alt. light
Old 07-29-2012, 05:35 AM
Hell Belcho
Nostril Cheese's Avatar
Dont run the engine with the battery disconnected. You risk frying the alternator.
Old 07-29-2012, 05:27 PM
Thanks I jumpered the pos side of the battery to DF. Sometimes my fingers get in the way of my brain I meant to say I applied 12v(battery) to the DF side of the alternator in my first posting.
Old 07-30-2012, 03:37 PM
