control arm
what is the best way to remove the control arm and what happens if i just pull the bolt if possible.
Old 07-06-2012, 09:13 AM
Scrappy's Avatar
I assume you mean the front .... you aren't just going to pull a bolt to remove it.
You will remove at least 5 before you can remove it.
Ron Meier
Backyard Shadetree Mechanic
1974 914/6 conversion with 2.7L (The Grey Ghost)
1973 Chalon with 2.4T MFI (Schlitzalom)
All my 4 cylinders are gone
Old 07-06-2012, 11:24 AM
sorry i should have said the rear. i see 3 bolts .
Old 07-06-2012, 01:04 PM
Scrappy's Avatar
There are 4 plus removal of the lower shock bolt. The 3 hold alignment shims underneath them. The 4th is on the ear opposite the 3 and is a 22 mm(?) nut. The shock bolt you can see also. You also need to disconnect / remove the caliper (2 bolts). Remove the brake line clips and set it free.
And I forgot, you have to remove the drive axles too!
They all have to be removed to remove the "trailing arm".
Ron Meier
Old 07-06-2012, 03:07 PM
thanks.71 914 conversion with a G6 3.5 fwd automatic squeezed in
Old 07-07-2012, 02:41 AM
Resident Electrician
Mike Bellis's Avatar
Can you post pics of your conversion?
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 07-07-2012, 06:07 PM
911buff
911buff's Avatar
Please post some pics. I have a bum knee and want to convert to an automatic. I have been told by "experts" that it is too expensive and can't be done. I am looking for some inspiration! Thanks!
Old 08-06-2012, 11:42 PM
914 Geek
Anything can be done, if you throw enough money and ingenuity at it.
There's a guy on the 914world BBS who has a four-cylinder 914 with an older Audi FWD auto transmission in it. A few parts of it look a little hack-ish, but he says it works reasonably well. That is probably the easiest one to do; I think the transmission bolt pattern may be the same, though that's relatively minor. But a longitudinal FWD gearbox means it turns the correct direction and stays in the stock location, both of which are less work than otherwise.
--DD
Old 08-07-2012, 09:04 AM
