record breaking brake conversion
well i just set a record breaking brake conversion
in 8 hours
i changed to a 19 mm master cylinder and up graded to 320 i calibers
that includes rebuilding the pedal cluster changing the master cylinder, painting the calibers after rebuilding, wire brushing, baking painted cailbers in the oven for an hour and installing them
you can even us the old hard lines if you are careful but have a spare ready just in case
for those who are doing this conversion split the calibers for machining it took 20 min to machine them just clamp on the split face vertically and do both faces at the same time and it even makes sure they are true
i will post pics of the calibers later
the problems i had were ....
i broke the break light switch
lost the gas pedal rod ( thank god for parts car on both )
and after i had every thing mounted i went to install the brake
pads that i ordered from PP and for some strange reason it had feredo 914 pads in a 320 i pagid box so wayne i will be calling
have fun and believe me rebuild you pedal cluster my brake pedal was sticking abd i did not even know it i had to beat it out
scott thacher
75 914 with 2.5 l 98 suby engine on the road
Old 06-02-2002, 11:32 AM
here are some pics
scott thacher
Old 06-02-2002, 04:29 PM
