Rebuilt Motor Timing
I've just completed the recommended 20 minute break-in run at 2000 RPM on my newly rebuilt 2.0 T4 and need to tweak the timing a bit. Is it okay to run the motor up to 3500 RPM to set the recommend 27 degrees BTDC this early in it's life?
Jack |
yes, you should be fine now to go up to that limit. You running break in oil?
Timing
Yes, I still have Brad Penn break-in oil in the motor.
Jack |
| All times are GMT -8. The time now is 07:03 AM. |
